Just wanted to say hey - TCCoA Forums
post #1 of 19 (permalink) Old 07-01-2010, 10:34 PM Thread Starter
Most of you aready know me here, there is prolly only a select few who dont, anyways just wanted to say check out the website www.robstireandauto.com and go under products to see some of our new products like, power stop brake pads, the newest addition is the upper ball joint boots, your old ones crack these slide right into place, anyways check it all out
Any question you can call the shop pm me here and ill be glad to help
Robert
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #2 of 19 (permalink) Old 07-02-2010, 12:43 AM
Howdy Rob, glad to see you here.
alan
post #3 of 19 (permalink) Old 07-02-2010, 04:26 AM
kpthefatty's Avatar
Welcome Robert
Hey I was looking at those Aeroforce Interceptor Gauges. How hard are those to install?
kpthefatty is offline
post #4 of 19 (permalink) Old 07-02-2010, 08:05 AM Thread Starter
There a breeze, do you know were your obd 2 plug is under the glove on the passenger side? If so the wire runs from the gauge to there and that's it there is no external wires required, this is truly a plug and play item, then u choose what item u want to moniter and those items can be changed at any time, basically u can have everthing in the list choose or just what u want, the gauge will monitor 2 things at a time if u wanna see something different there is a switch to toggle between the items.
Any other questions just ask
Robert
10.75 @128.38
RobertP is offline
post #5 of 19 (permalink) Old 07-02-2010, 09:49 AM
kpthefatty's Avatar
Will it tell me what my check engine light is on for?
post #6 of 19 (permalink) Old 07-02-2010, 09:56 AM
No, they won't do that.
You need a OBDII scanner to check and clear the codes that cause the check engine light to come on. Sometimes you can clear them and they won't come back other times there's a recurring problem that needs to be fixed.
Most autoparts stores will check and clear the code for free.
post #7 of 19 (permalink) Old 07-02-2010, 09:59 AM
kpthefatty's Avatar
Autozones crappy scanner wont turn on with my 95. They just argue with me and tell me that its OBDI.
post #8 of 19 (permalink) Old 07-02-2010, 10:02 AM
Go buy your own OBDII scanner. New or used, it's money well spent.
You may be able to find them used on Ebay for cheap.
post #9 of 19 (permalink) Old 07-02-2010, 10:05 AM Thread Starter
actually trunk monkey they do u go under the menu and click get dtcs it will give ou the code and all and you can clear codes with it i just forgot to tell you about that Trunk monkey
10.75 @128.38
RobertP is offline
post #10 of 19 (permalink) Old 07-02-2010, 10:09 AM
Ok, I stand corrected.
post #11 of 19 (permalink) Old 07-02-2010, 10:09 AM
kpthefatty's Avatar
Sweet!
Way to fail TM!
post #12 of 19 (permalink) Old 07-02-2010, 10:47 AM Thread Starter
it really is the sweetest gauge out there u can even do 2 inputs like say u wanted to add and oil pressure gauge, no problem i sell a kit for that also and the gauge has different headings for the inputs like on mine i have boost and oil pressure lots of different things
Also you can run 2 gauges i believe red97tbird boght that setup from me awhile back
10.75 @128.38
RobertP is offline
post #13 of 19 (permalink) Old 07-03-2010, 10:16 AM
I will get some eventually... just haven't found a gauge pod I like yet. But will get dual gauges and hook up dual widebands to them. And probably some other stuff. haha. I have an info center for most things so it's not like I really NEED them.
FunktasticLucky is offline
post #14 of 19 (permalink) Old 07-11-2010, 03:10 PM
danalba's Avatar
awesome website looking forward to purchasing from you
MAC CAI/02 STANG MAF/SCT CHIP TUNED BY LONNIE
EIBACH 1.5 LOWERING SPRINGS- BILSTEIN GAS SHOCKS
90 SUPERCOUPE SIDE SKIRTS/REAR
18x9-FRONT: 245 REAR: 275
PI intake/PI cams
355 trac lok
new tune for swapped parts (93 oct)
no longer the owner.... but its still my child its just released into the world....
danalba is offline
post #15 of 19 (permalink) Old 07-16-2010, 01:31 AM
really i had a 94 and i lived in cali and now texas same scanner and it works. Make sure something didn't corrode.
Forgive me When i sound like i have A.D.D.
frst4.6 is offline
post #16 of 19 (permalink) Old 07-24-2010, 12:08 PM
Assaultdog0351's Avatar
Send a message via AIM to Assaultdog0351 Send a message via Yahoo to Assaultdog0351
Hey rob would those gauges fit in those scp gauge pods?
RTLB, RSTB, FSTB, LECB and FSSB, MAC intake, black interior and new shoes... Soon to come: SVO blower,, AIS, SS kooks headers, SS 2.5" dual exhaust w/ x-pipes and borlas, koni shocks, 1.6" vogland drop, poly (almost)everything, 1 3/8 F&R swaybars, rebuilt suspension... Parts collection nearing completion, contemplating the "Do" phase... More like "Pay someone else to do" phase... I blame the slow results on deployments and pre-deployment training... Kill
*currently planning some chassis work*
Assaultdog0351 is offline
post #17 of 19 (permalink) Old 07-24-2010, 01:15 PM Thread Starter
Yes there 2 1/16 standard size gauges
Robert
10.75 @128.38
RobertP is offline
post #18 of 19 (permalink) Old 07-24-2010, 08:15 PM
would I need to get the boost sensor they sell to monitor boost and also the same for a/f or does it already do that with what the kit comes with
post #19 of 19 (permalink) Old 07-24-2010, 09:05 PM Thread Starter
No, you would need the boost kit for it and the air fuel ratio if u wanted that, the gauges only monitor what the computer is capable of
Robert
10.75 @128.38
RobertP is offline
HTML code is Off
